跳转到主内容
Panasonic DMP-BD89 Wifi Board Replacement
你所需要的
  1. Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: 步骤 1 中的图像 1,2 Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: 步骤 1 中的图像 2,2
    • First, before powering off, press the eject button to open the tray.
  2. Panasonic DMP-BD89 Wifi Board Replacement: 步骤 2 中的图像 1,3 Panasonic DMP-BD89 Wifi Board Replacement: 步骤 2 中的图像 2,3 Panasonic DMP-BD89 Wifi Board Replacement: 步骤 2 中的图像 3,3
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
  3. Panasonic DMP-BD89 Wifi Board Replacement: 步骤 3 中的图像 1,2 Panasonic DMP-BD89 Wifi Board Replacement: 步骤 3 中的图像 2,2
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
  4. Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: 步骤 4 中的图像 1,2 Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: 步骤 4 中的图像 2,2
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
  5. Panasonic DMP-BD89 Wifi Board Replacement: 步骤 5 中的图像 1,1
    • Slide the top panel horizontally to remove it.
  6. Panasonic DMP-BD89 Wifi Board Replacement: 步骤 6 中的图像 1,3 Panasonic DMP-BD89 Wifi Board Replacement: 步骤 6 中的图像 2,3 Panasonic DMP-BD89 Wifi Board Replacement: 步骤 6 中的图像 3,3
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
  7. Panasonic DMP-BD89 Wifi Board Replacement: 步骤 7 中的图像 1,1
    • Pop the 6 markers out.
    • Then take off the cover.
  8. Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: 步骤 8 中的图像 1,2 Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: 步骤 8 中的图像 2,2
    • Locate reddish brown cable. Detach from green circuit board by pulling upward.
  9. Panasonic DMP-BD89 Wifi Board Replacement: 步骤 9 中的图像 1,1
    • Using tweezer, compress the white knob holding the wifi module board in place.
  10. Panasonic DMP-BD89 Wifi Board Replacement: 步骤 10 中的图像 1,2 Panasonic DMP-BD89 Wifi Board Replacement: 步骤 10 中的图像 2,2
    • Pull the module board straight up, removing completely. The second photo is how your device should look with the WiFi board removed.
结论
另外一个人完成了本指南。
Mohan Saxena
于10/17/17注册
133 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 374
