简介
This guide will help removed and replaced your damaged or old motherboard. If you have problems turning on your camera and you have checked your battery then you may need to follow this guide to replace the motherboard. Before you begin, make sure that the battery and SD card have been removed.
你所需要的
Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
3等其他人完成本指南。
