跳转到主内容
Panasonic DMC-FZ70 Motherboard Replacement
你所需要的
  1. Panasonic DMC-FZ70 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Panasonic DMC-FZ70 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Panasonic DMC-FZ70 Motherboard Replacement: 步骤 2 中的图像 1,2 Panasonic DMC-FZ70 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Panasonic DMC-FZ70 Motherboard Replacement: 步骤 3 中的图像 1,2 Panasonic DMC-FZ70 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. Panasonic DMC-FZ70 Motherboard Replacement: 步骤 4 中的图像 1,2 Panasonic DMC-FZ70 Motherboard Replacement: 步骤 4 中的图像 2,2
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Panasonic DMC-FZ70 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  6. Panasonic DMC-FZ70 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  7. Panasonic DMC-FZ70 Motherboard Replacement: 步骤 7 中的图像 1,3 Panasonic DMC-FZ70 Motherboard Replacement: 步骤 7 中的图像 2,3 Panasonic DMC-FZ70 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
  8. Panasonic DMC-FZ70 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Using a Torx driver, unscrew the two 5mm Phillipd screws on the motherboard
  9. Panasonic DMC-FZ70 Motherboard Replacement: 步骤 9 中的图像 1,3 Panasonic DMC-FZ70 Motherboard Replacement: 步骤 9 中的图像 2,3 Panasonic DMC-FZ70 Motherboard Replacement: 步骤 9 中的图像 3,3
    • The five ribbon cables shown will need to be removed from the ZIF connectors. Using a plastic opening tool, unlock the cables by lifting the black strip on the rectangular connection socket.
    • Carefully pull each of the ribbon cables out of their sockets.
    • The cable should slide out smoothly- any significant resistance might signal that the locking lever has not yet released the cable.
  10. Panasonic DMC-FZ70 Motherboard Replacement: 步骤 10 中的图像 1,2 Panasonic DMC-FZ70 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Once the screws and the ribbon cables have been removed, lift the mother board from its slot.
结论
3等其他人完成本指南。
Emily Kuzmicky
于01/24/17注册
448 声望
创作了2篇指南
团队
Cal Poly, Team 21-3, Maness Winter 2017 Cal Poly, Team 21-3, Maness Winter 2017 的会员
CPSU-MANESS-W17S21G3
6 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 25
总计 1,740
