跳转到主内容
Panasonic D-snap SV-AV50 Screen Replacement
你所需要的
  1. Panasonic D-snap SV-AV50 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
    • Then, rotate the screen 180 degrees and remove the screw on the opposite side.
  2. Panasonic D-snap SV-AV50 Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
  3. Panasonic D-snap SV-AV50 Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the backing away from the screen as shown in the photo.
  4. Panasonic D-snap SV-AV50 Screen Replacement: 步骤 4 中的图像 1,1
    • Unplug the black connector between the camera and the screen by pulling down.
    • For increased ease, use tweezers or forceps, as seen in the picture
  5. Panasonic D-snap SV-AV50 Screen Replacement: 步骤 5 中的图像 1,1
    • Pull the screen away from the camera the same way that you removed the screen backing.
  6. Panasonic D-snap SV-AV50 Screen Replacement: 步骤 6 中的图像 1,1
    • Use the screwdriver to remove the screw(2.46mm Philips) indicated.
  7. Panasonic D-snap SV-AV50 Screen Replacement: 步骤 7 中的图像 1,1
    • Pull upwards on the screen border to remove it from the actual screen.
结论
Zoe Hinck
于04/12/12注册
29 声望
创作了4篇指南
团队
Cal Poly, Team 6-19, Amido Spring 2012 Cal Poly, Team 6-19, Amido Spring 2012 的会员
CPSU-AMIDO-S12S6G19
3 名成员
创作了12篇指南
一条评论
I need the LCD screen, can you helpme?
leon - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,062
