跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Be sure to remove the battery and SD card before opening the camera to get to the screen component.
配件
没有特定配件。
  1. Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
    • Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
    • Then, rotate the screen 180 degrees and remove the screw on the opposite side.
  2. Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
    • Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
  3. Pull the backing away from the screen as shown in the photo.
    • Pull the backing away from the screen as shown in the photo.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Unplug the black connector between the camera and the screen by pulling down.
    • Unplug the black connector between the camera and the screen by pulling down.
    • For increased ease, use tweezers or forceps, as seen in the picture
  6. Pull the screen away from the camera the same way that you removed the screen backing.
    • Pull the screen away from the camera the same way that you removed the screen backing.
  7. Use the screwdriver to remove the screw(2.46mm Philips) indicated.
    • Use the screwdriver to remove the screw(2.46mm Philips) indicated.
  8. Pull upwards on the screen border to remove it from the actual screen.
    • Pull upwards on the screen border to remove it from the actual screen.
结论
Zoe Hinck
于2012年04月12日注册
29 信誉积分
创作了4篇指南
团队
Cal Poly, Team 6-19, Amido Spring 2012 Cal Poly, Team 6-19, Amido Spring 2012 的会员
CPSU-AMIDO-S12S6G19
3 名成员
创作了6篇指南
I need the LCD screen, can you helpme?
leon - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 814
