当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Remove the piece of the frame that covers the camera's function buttons by pulling upwards from the end, as shown in the picture.
It may feel like you are breaking the camera, since the frame makes a snapping sound as you remove it. However, as long as you are careful to remove the frames individually as shown, the frames will probably not break.
这个步骤还没有翻译 帮忙翻译一下
Turn the camera and remove the frame from the opposite side of the camera by pulling from either the top or the bottom in an outwards direction.
As in the previous step, it may seem like you are breaking the camera, because the frame makes snapping noises, as you pull it apart.This is to be expected, and will not harm the camera.
