跳转到主内容
Panasonic Camera DMC FX37 Battery Door Replacement
你所需要的
  1. Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: 步骤 1 中的图像 1,2 Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: 步骤 1 中的图像 2,2
    • Set the switch on the battery door to "open," and open the door.
  2. Panasonic Camera DMC FX37 Battery Door Replacement: 步骤 2 中的图像 1,1
    • At the left hand side, locate the head of the metal bar that holds the spring in place.
  3. Panasonic Camera DMC FX37 Battery Door Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Push the metal bar down using the metal tweezers.
  4. Panasonic Camera DMC FX37 Battery Door Replacement: 步骤 4 中的图像 1,1
    • Pull the metal bar that holds the spring in place out.
    • You can also use tweezers for this step, although we found it easier to just use our fingers.
  5. Panasonic Camera DMC FX37 Battery Door Replacement: 步骤 5 中的图像 1,1
    • Remove the battery access door from the device.
    • In order to keep the "springiness" of the door, be sure that the long arm of the spring is not over the hole for the battery.
结论
Zhentao
于01/30/18注册
247 声望
创作了2篇指南
团队
Baylor, Team S2-G3, Johnson Spring 2018 Baylor, Team S2-G3, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 289
