跳转到主内容
Panasonic CF-31 Toughbook Keyboard Replacement
你所需要的
  1. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: 步骤 1 中的图像 1,3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: 步骤 1 中的图像 2,3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Open the battery compartment by pulling the tab forward and then down.
    • Open the compartment door by pushing down.
    • Use the plastic tab to pull the battery out of the compartment.
  2. Panasonic CF-31 Toughbook  Keyboard  Replacement: 步骤 2 中的图像 1,2 Panasonic CF-31 Toughbook  Keyboard  Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the three screws from the bezel.
    • Use a nylon spudger to remove the bezel.
  3. Panasonic CF-31 Toughbook  Keyboard  Replacement: 步骤 3 中的图像 1,2 Panasonic CF-31 Toughbook  Keyboard  Replacement: 步骤 3 中的图像 2,2
    • Use a nylon spudger to lift each corner of the keyboard.
    • Use your hands and gently pull back to remove the keyboard.
  4. Panasonic CF-31 Toughbook  Keyboard  Replacement: 步骤 4 中的图像 1,2 Panasonic CF-31 Toughbook  Keyboard  Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips # 2 screwdriver to remove the four screws securing the keyboard shield.
    • Remove the keyboard shield.
  5. Panasonic CF-31 Toughbook  Keyboard  Replacement: 步骤 5 中的图像 1,1
    • Remove the top left ribbon cable using a nylon spudger to pull the top and bottom tabs right.
  6. Panasonic CF-31 Toughbook  Keyboard  Replacement: 步骤 6 中的图像 1,1
    • Remove the top right ribbon cable using a nylon spudger and push the top and bottom tabs left.
  7. Panasonic CF-31 Toughbook  Keyboard  Replacement: 步骤 7 中的图像 1,2 Panasonic CF-31 Toughbook  Keyboard  Replacement: 步骤 7 中的图像 2,2
    • Remove the bottom left ribbon cable using a nylon spudger and push the top and bottom tabs right.
结论
To reassemble the Panasonic CF-31 Toughbook Laptop, follow these instructions in reverse order.
Richard Gill
于01/16/19注册
145 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 46
总计 2,484
