跳转到主内容
Panasonic ARC ES-LT3N Power Button Replacement
你所需要的
  1. Panasonic ARC ES-LT3N Power Button Replacement, Back Casing: 步骤 1 中的图像 1,2 Panasonic ARC ES-LT3N Power Button Replacement, Back Casing: 步骤 1 中的图像 2,2
    • Flip the razor over so the back is facing you.
  2. Panasonic ARC ES-LT3N Power Button Replacement: 步骤 2 中的图像 1,2 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
  3. Panasonic ARC ES-LT3N Power Button Replacement: 步骤 3 中的图像 1,2 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 3 中的图像 2,2
    • Slide the plastic cover at the bottom of the razor downward to remove.
  4. Panasonic ARC ES-LT3N Power Button Replacement: 步骤 4 中的图像 1,2 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 4 中的图像 2,2
    • Lift up the rear casing from the bottom of the razor.
    • This may require you to gently pry it apart with you fingers.
    • Lift up the rear casing from the sides of the razor.
    • Pull rear casing up and off razor.
    • Be careful not to break any plastic!
  5. Panasonic ARC ES-LT3N Power Button Replacement, Battery: 步骤 5 中的图像 1,1
    • Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
  6. Panasonic ARC ES-LT3N Power Button Replacement: 步骤 6 中的图像 1,1
    • Remove battery case.
  7. Panasonic ARC ES-LT3N Power Button Replacement: 步骤 7 中的图像 1,2 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 7 中的图像 2,2
    • Remove old battery by lifting the battery up and left.
    • There are plastic brackets holding the battery on the right. Removing up and left ensures that the brackets will not be damaged and the battery will not come loose.
  8. Panasonic ARC ES-LT3N Power Button Replacement, Power Button: 步骤 8 中的图像 1,3 Panasonic ARC ES-LT3N Power Button Replacement, Power Button: 步骤 8 中的图像 2,3 Panasonic ARC ES-LT3N Power Button Replacement, Power Button: 步骤 8 中的图像 3,3
    • Remove the 8 mm screws directly below the lock switch.
  9. Panasonic ARC ES-LT3N Power Button Replacement: 步骤 9 中的图像 1,3 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 9 中的图像 2,3 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 9 中的图像 3,3
    • Push the lock switch upward and remove the 6 mm screw hidden beneath.
  10. Panasonic ARC ES-LT3N Power Button Replacement: 步骤 10 中的图像 1,2 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 10 中的图像 2,2
    • Remove the lock switch by sliding it downward until it is out of place.
  11. Panasonic ARC ES-LT3N Power Button Replacement: 步骤 11 中的图像 1,3 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 11 中的图像 2,3 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 11 中的图像 3,3
    • Starting from the bottom, lift the front casing upward to separate the case from the device.
    • Continue to lift the device upward until you can pull the casing off.
    • It may take some wiggling or slight bending of the plastic to remove all the way.
  12. Panasonic ARC ES-LT3N Power Button Replacement: 步骤 12 中的图像 1,3 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 12 中的图像 2,3 Panasonic ARC ES-LT3N Power Button Replacement: 步骤 12 中的图像 3,3
    • Remove the button.
结论
Andrew Trainor
于03/05/17注册
648 声望
创作了5篇指南
团队
UMass Dartmouth, Team S8-G3, Catania Spring 2017 UMass Dartmouth, Team S8-G3, Catania Spring 2017 的会员
UMASSD-CATANIA-S17S8G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 504
