跳转到主内容
PalmOne Zire 72 Control Pad Replacement
你所需要的
  1. PalmOne Zire 72 Control Pad Replacement, Control Pad: 步骤 1 中的图像 1,2 PalmOne Zire 72 Control Pad Replacement, Control Pad: 步骤 1 中的图像 2,2
    • Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
  2. PalmOne Zire 72 Control Pad Replacement: 步骤 2 中的图像 1,1
    • Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
    • If you peel the entire adhesive off, two holes underneath will be exposed to future damage. Try to preserve the label to reapply later.
    • Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
  3. PalmOne Zire 72 Control Pad Replacement: 步骤 3 中的图像 1,1
    • Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
  4. PalmOne Zire 72 Control Pad Replacement: 步骤 4 中的图像 1,1
    • Use either end of the spudger to carefully pry off the camera lens mesh cover.
  5. PalmOne Zire 72 Control Pad Replacement: 步骤 5 中的图像 1,1
    • Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
  6. PalmOne Zire 72 Control Pad Replacement: 步骤 6 中的图像 1,2 PalmOne Zire 72 Control Pad Replacement: 步骤 6 中的图像 2,2
    • Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
    • Gently remove the case to avoid damaging it. Do not try to force the case open.
    • The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
  7. PalmOne Zire 72 Control Pad Replacement: 步骤 7 中的图像 1,2 PalmOne Zire 72 Control Pad Replacement: 步骤 7 中的图像 2,2
    • Remove the cover by lifting it from right to left.
    • This should be similar to the action of the opening of a book.
    • The brown film connecting the motherboard to the screen may tear if this is not done carefully.
  8. PalmOne Zire 72 Control Pad Replacement: 步骤 8 中的图像 1,1
    • Lift the control pad buttons off of the motherboard.
结论
团队
Cal Poly, Team 6-49, Amido Spring 2012 Cal Poly, Team 6-49, Amido Spring 2012 的会员
CPSU-AMIDO-S12S6G49
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 425
