跳转到主内容
Palm v Outer Case Replacement
你所需要的
  1. Palm v Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Lay device face down on surface.
  2. Palm v Outer Case Replacement: 步骤 2 中的图像 1,2 Palm v Outer Case Replacement: 步骤 2 中的图像 2,2
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v Outer Case Replacement: 步骤 3 中的图像 1,1
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v Outer Case Replacement: 步骤 4 中的图像 1,1
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v Outer Case Replacement: 步骤 5 中的图像 1,3 Palm v Outer Case Replacement: 步骤 5 中的图像 2,3 Palm v Outer Case Replacement: 步骤 5 中的图像 3,3
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
终点
Anthony Platt
于02/09/10注册
66 声望
创作了3篇指南
团队
Cal Poly, Team 13-25, Maness Winter 2010 Cal Poly, Team 13-25, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G25
4 名成员
创作了4篇指南
一条评论
So...This given by my grandmother and it is out of battery. Unluckily, it won't charge, because the %#*@ old battery had gone kaput. I had a hard time finding one that might be suitable, and turnout that I need to insert it into the device and connect it to the circuit board. I have some solid soldering skills, but without a heat gun, the andonized cover won't come off. And what's more, I jammed a pencil tip into the "reset" hole when trying to reset the device. Thinking the big opening was a kind of cover-releasing button...I was just having a whole lot of trouble and thinking too much. !&&*.
Xavier Jiang - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,587
