当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Heat the left and top edges with hairdryer for one minute.
Move hairdryer back and forth to evenly heat up surface.
Caution: directly heating the screen can melt or distort the screen.
Use tweezers to hold Palm right side down on it's side.
Use a plastic opening tool to pry open front and back casing.
If you are unable to open you may need to heat with hairdryer for longer.
Be sure not to touch case directly with fingers, it will be hot!
Now pry open front and back casing with plastic opening tools.
Separate front and back casing completely.
Power button will fall off once front and back casing have been removed. Be sure not to lose it.
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
Now you must flip up the adjacent clamp as well, using tweezers like before.
After the clamp is flipped you can gently remove the second ribbon with tweezers.
Before removing the screen you must detach one more wire, the battery connector.
Using the tweezers, squeeze the connector attached to the wire and genlty pull.
Do not pull from the wire.
Lift up the black flap covering the ribbon cable with your hand
With the spudger, left green cable clamp
Gently remove ribbon cable from clamp
With your hands, pop out the logic board from the casing
If board bends significantly, trying pushing from another angle
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
