跳转到主内容
Palm v Logic Board Replacement
你所需要的
  1. Palm v Logic Board Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Lay device face down on surface.
  2. Palm v Logic Board Replacement: 步骤 2 中的图像 1,2 Palm v Logic Board Replacement: 步骤 2 中的图像 2,2
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v Logic Board Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v Logic Board Replacement: 步骤 4 中的图像 1,1
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v Logic Board Replacement: 步骤 5 中的图像 1,3 Palm v Logic Board Replacement: 步骤 5 中的图像 2,3 Palm v Logic Board Replacement: 步骤 5 中的图像 3,3
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
  6. Palm v Logic Board Replacement, Screen: 步骤 6 中的图像 1,2 Palm v Logic Board Replacement, Screen: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
    • To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
    • Once the clamp is up you can use the tweezers to gently detach the ribbon.
  7. Palm v Logic Board Replacement: 步骤 7 中的图像 1,3 Palm v Logic Board Replacement: 步骤 7 中的图像 2,3 Palm v Logic Board Replacement: 步骤 7 中的图像 3,3
    • Now you must flip up the adjacent clamp as well, using tweezers like before.
    • After the clamp is flipped you can gently remove the second ribbon with tweezers.
  8. Palm v Logic Board Replacement: 步骤 8 中的图像 1,2 Palm v Logic Board Replacement: 步骤 8 中的图像 2,2
    • Before removing the screen you must detach one more wire, the battery connector.
    • Using the tweezers, squeeze the connector attached to the wire and genlty pull.
    • Do not pull from the wire.
  9. Palm v Logic Board Replacement: 步骤 9 中的图像 1,1
    • Now that both ribbons and the wire are disconeccted, you can apply a downward pressure to the battery. You will have to carefully rotate the frame so that the battery can go through.
  10. Palm v Logic Board Replacement, Logic Board: 步骤 10 中的图像 1,1
    • Lift up the black flap covering the ribbon cable with your hand
    • With the spudger, left green cable clamp
    • Gently remove ribbon cable from clamp
  11. Palm v Logic Board Replacement: 步骤 11 中的图像 1,1
    • With your hands, pop out the logic board from the casing
    • If board bends significantly, trying pushing from another angle
结论
Anthony Platt
于02/09/10注册
66 声望
创作了3篇指南
团队
Cal Poly, Team 13-25, Maness Winter 2010 Cal Poly, Team 13-25, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G25
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,429
