简介
The purpose to this guide is to show how to properly replace the screen on a Palm V.
你所需要的
在这个步骤中使用的工具:Tweezers$4.99
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
终点
另外一个人完成了本指南。
1指南评论
Can the electroluminescent backlight panel be separated from the LCD? Then clip out the wires related to the LCD? Is that possible or are they fused?
