跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Palm m500 LCD Screen Replacement
你所需要的
  1. Palm m500 LCD Screen Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the stylus from the side of the PDA by sliding it upwards.
  2. Palm m500 LCD Screen Replacement: 步骤 2 中的图像 1,2 Palm m500 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
  3. Palm m500 LCD Screen Replacement: 步骤 3 中的图像 1,3 Palm m500 LCD Screen Replacement: 步骤 3 中的图像 2,3 Palm m500 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
  4. Palm m500 LCD Screen Replacement, Battery: 步骤 4 中的图像 1,3 Palm m500 LCD Screen Replacement, Battery: 步骤 4 中的图像 2,3 Palm m500 LCD Screen Replacement, Battery: 步骤 4 中的图像 3,3
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
  5. Palm m500 LCD Screen Replacement, Motherboard: 步骤 5 中的图像 1,3 Palm m500 LCD Screen Replacement, Motherboard: 步骤 5 中的图像 2,3 Palm m500 LCD Screen Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to pry the orange clamp away from the motherboard.
    • Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
    • Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
  6. Palm m500 LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 1,2 Palm m500 LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 2,2
    • Pull the LCD screen up from the bottom of the device using your forefinger.
    • The LCD screen will easily come away from the front panel.
结论
另外一个人完成了本指南。
Miles Johnson
于01/11/11注册
579 声望
创作了4篇指南
团队
Cal Poly, Team 14-9, Forte Winter 2011 Cal Poly, Team 14-9, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G9
6 名成员
创作了6篇指南
一条评论
The hardest part is getting the back plate off, I throttled my plastic spudger.
dpchoung - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,144
