跳转到主内容
简介
Before you begin disassembly, be sure to have the necessary tools. You will need a Torx size T6 screwdriver, tweezers, and the device opening tool. You will be removing the stylus, the back panel, the battery, and the motherboard in order to access the LCD screen.
  1. Remove the stylus from the side of the PDA by sliding it upwards.
    • Remove the stylus from the side of the PDA by sliding it upwards.
  2. Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver. Place screws in a plastic bag or another safe place.
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
  3. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  4. Insert the edge of the plastic opening tool between the back panel and the black stylus holder. Carefully and forcefully pry the panels apart. Carefully and forcefully pry the panels apart.
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
  5. Use tweezers to unplug the battery cable from the motherboard socket. Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards. The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
  6. Use the plastic opening tool to pry the orange clamp away from the motherboard. Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate. Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
    • Use the plastic opening tool to pry the orange clamp away from the motherboard.
    • Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
    • Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
  7. Pull the LCD screen up from the bottom of the device using your forefinger. The LCD screen will easily come away from the front panel.
    • Pull the LCD screen up from the bottom of the device using your forefinger.
    • The LCD screen will easily come away from the front panel.
结论
另外一个人完成了本指南。
Miles Johnson
于2011年01月11日注册
526 信誉积分
创作了4篇指南
团队
Cal Poly, Team 14-9, Forte Winter 2011 Cal Poly, Team 14-9, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G9
6 名成员
创作了6篇指南
The hardest part is getting the back plate off, I throttled my plastic spudger.
dpchoung - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 3
总计 1,708
