跳转到主内容
Palm m105 Display Screen Replacement
你所需要的
  1. Palm m105 Display Screen Replacement, Display Screen: 步骤 1 中的图像 1,1
    • Flip the protective cover open and pull it straight away from the device to release the two clips.
  2. Palm m105 Display Screen Replacement: 步骤 2 中的图像 1,1
    • To remove the faceplate, locate the tab at the top of the device.
    • Lift the tab upwards with your finger.
    • The tab releases easily. Excessive force is not required.
  3. Palm m105 Display Screen Replacement: 步骤 3 中的图像 1,2 Palm m105 Display Screen Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    T5 Torx Screwdriver
    $5.49
    • Using a T5 Torx screwdriver, remove the four screws located on the back of the device.
    • With the screws removed, the device is separated into two parts (the empty back cover and the back case holding the main components).
  4. Palm m105 Display Screen Replacement: 步骤 4 中的图像 1,1
    • Be careful with this step. The motherboard and screen are attached by fragile cables.
    • Slowly lift the motherboard and the screen from the back case.
    • Gently hold the screen back so that you see the cables between it and the motherboard.
  5. Palm m105 Display Screen Replacement: 步骤 5 中的图像 1,2 Palm m105 Display Screen Replacement: 步骤 5 中的图像 2,2
    • Detach the screen from the motherboard by carefully pulling up on the three tabs.
    • Be careful. These tabs are fragile.
    • The motherboard and screen separate once the three tabs are released.
    • Recycle the old screen.
结论
Erik Thompson
于10/04/11注册
31 声望
创作了5篇指南
团队
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S1G3
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 867
