跳转到主内容
Palm m105 Display Screen Replacement
你所需要的
  1. Palm m105 Display Screen Replacement, Display Screen: 步骤 1 中的图像 1,1
    • Remove protective flap by pulling directly out from the top.
    • The two clips will pop out
  2. Palm m105 Display Screen Replacement: 步骤 2 中的图像 1,1
    • Remove Faceplate. There is a tab where the finger is located in the picture that needs to be pulled up.
    • The Faceplate will then easily lift off.
  3. Palm m105 Display Screen Replacement: 步骤 3 中的图像 1,2 Palm m105 Display Screen Replacement: 步骤 3 中的图像 2,2
    • Using a a T5 Torx bit screwdriver, remove the four screws located on the back of the device turning counter clockwise.
    • The link to purchase this screwdriver is Located here.
  4. Palm m105 Display Screen Replacement: 步骤 4 中的图像 1,1
    • This is what the device looks like once you have taken the screws out and opened the device.
  5. Palm m105 Display Screen Replacement: 步骤 5 中的图像 1,1
    • The Motherboard and screen will pop out of the back case easily.
    • Be careful when doing this step, the components are fragile.
  6. Palm m105 Display Screen Replacement: 步骤 6 中的图像 1,1
    • To remove the screen from the motherboard there are going to be three tabs that need to pulled up.
    • ** This step needs to be done with special care because it is very fragile.**
    • Once they are all three popped up the motherboard and screen will separate easily.
  7. Palm m105 Display Screen Replacement: 步骤 7 中的图像 1,1
    • Click here for Palm m105 screen replacement
    • Now that the screen and motherboard are separated you may discard the broken screen. The best way to dispose of the broken screen is to: Recycle it
结论
Erik Thompson
于10/04/11注册
31 声望
创作了5篇指南
团队
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S1G3
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 652
