跳转到主内容
加入维修社区 - 创建账户
Palm m105 Button Replacement
你所需要的
  1. Palm m105 Button Replacement, Buttons: 步骤 1 中的图像 1,1
    • Begin with the Palm m105 facing you on a flat surface.
  2. Palm m105 Button Replacement: 步骤 2 中的图像 1,1
    • Remove the protective screen cover by flipping it up and pulling it directly away from the top of the device.
    • The two clips located on the protective screen should pop out.
  3. Palm m105 Button Replacement: 步骤 3 中的图像 1,1
    • To remove the faceplate, lift the tab located at the top of the device.
    • The faceplate should easily lift off.
  4. Palm m105 Button Replacement: 步骤 4 中的图像 1,3 Palm m105 Button Replacement: 步骤 4 中的图像 2,3 Palm m105 Button Replacement: 步骤 4 中的图像 3,3
    • Using a T-5 Torx screwdriver, remove all four screws located on the back of the device. Turn counterclockwise to remove screws. The link to purchase this screwdriver is located at the top of this page.
    • Once you have removed all four screws, the device will be in three separate pieces (the back, the computer, and the button board).
    • Take caution as the power button will become loose after this step is completed.
  5. Palm m105 Button Replacement: 步骤 5 中的图像 1,1
    • After step four, locate the button board. The button board should have a frame attached to it. Remove this frame.
    • To remove the buttons from the frame, apply even pressure on two buttons at a time. This should make them pop out easily. Once you have removed the buttons, you can now wash or replace them.
    • To insert a new set of buttons, push it back into the opening on the faceplate, and you should feel it click into place.
结论
另外一个人完成了本指南。
Erik Thompson
于10/04/11注册
31 声望
创作了5篇指南
团队
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S1G3
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 687
