跳转到主内容
Palm m 100 Display Screen Replacement
你所需要的
  1. Palm m 100 Display Screen Replacement, Display Screen: 步骤 1 中的图像 1,1
    • Remove the batteries.
  2. Palm m 100 Display Screen Replacement: 步骤 2 中的图像 1,1
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Display Screen Replacement: 步骤 3 中的图像 1,1
    • Remove rear cover by gently lifting it up from the bottom.
  4. Palm m 100 Display Screen Replacement: 步骤 4 中的图像 1,1
    • Carefully lift up the circuit board, which will also lift up the screen. Do so carefully to prevent breaking the connectors.
    • Lift the left side of the circuit board and open it as though it were a book.
  5. Palm m 100 Display Screen Replacement: 步骤 6 中的图像 1,1
    • Unplug the three connectors located on the right side of the circuit board with great caution and care. Do not pull by the cable, and be sure to pull the connector itself gently.
    • After separating the screen from the board, set aside the old display screen.
    • Replace with a new display screen.
  6. Palm m 100 Display Screen Replacement: 步骤 9 中的图像 1,1
    • Plug in the three connectors.
  7. Palm m 100 Display Screen Replacement: 步骤 10 中的图像 1,1
    • Close again like a book, and lay it gently into the front panel, screen facing outwards of the front panel.
  8. Palm m 100 Display Screen Replacement: 步骤 11 中的图像 1,1
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
结论
Lexi Gallucci
于10/18/11注册
11 声望
创作了2篇指南
团队
James Madison, Team 1-3, Allen Fall 2011 James Madison, Team 1-3, Allen Fall 2011 的会员
JMU-ALLEN-F11S1G3
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 685
