简介
The Palm Zire m150 may sometimes need a motherboard replacement depending on the diagnosis. This guide will teach you how to replace that motherboard if that is the remedy needed after going through the troubleshooting steps.
你所需要的
Lift up the flap on the Palm Zire M150.
If you wish to remove it, gently lift up and pull horizontally. It should come off without an issue.
即将完成!
结论
另外一个人完成了本指南。
