跳转到主内容
Palm Zire m150 Headphone Jack Replacement
你所需要的
  1. Palm Zire m150 Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,2 Palm Zire m150 Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 2,2
    • Remove cover, also known as the flap from the Palm Zire m150.
    • For the purpose of this guide and being able to see clearly, we removed the flap completely. You can keep your flap on if you wish.
  2. Palm Zire m150 Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Remove both screws on the back.
    • Turn screw driver counterclockwise to remove screw
    • Be careful not to strip screws
  3. Palm Zire m150 Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Remove the front part of the device from the bottom part of the device.
    • Separate front cover from back cover.
    • Be careful not to break the connector that connects the screen to motherboard.
  4. Palm Zire m150 Headphone Jack Replacement: 步骤 4 中的图像 1,2 Palm Zire m150 Headphone Jack Replacement: 步骤 4 中的图像 2,2
    • Insert NEW audio piece into the top case housing.
    • On the NEW audio piece, use a soldering iron to solder.
    • Let solder cool before reassembling unit.
    • Soldering iron needs time to warm up in order for use
结论
Kate
于01/26/16注册
528 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 325
