跳转到主内容
Palm Zire 71 Motherboard/Screen Replacement
你所需要的
  1. Palm Zire 71 Motherboard/Screen Replacement, Preparation: 步骤 1 中的图像 1,1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Motherboard/Screen Replacement, Top Screws (2) Removal: 步骤 2 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Motherboard/Screen Replacement, Bottom Screws (3) Removal: 步骤 3 中的图像 1,1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Motherboard/Screen Replacement, Front Panel Removal: 步骤 4 中的图像 1,2 Palm Zire 71 Motherboard/Screen Replacement, Front Panel Removal: 步骤 4 中的图像 2,2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Motherboard/Screen Replacement, Bracket and Speaker Removal: 步骤 5 中的图像 1,2 Palm Zire 71 Motherboard/Screen Replacement, Bracket and Speaker Removal: 步骤 5 中的图像 2,2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Motherboard/Screen Replacement, Back Cover: 步骤 6 中的图像 1,2 Palm Zire 71 Motherboard/Screen Replacement, Back Cover: 步骤 6 中的图像 2,2
    • Slide the back cover off.
  7. Palm Zire 71 Motherboard/Screen Replacement, Battery: 步骤 7 中的图像 1,1
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  8. Palm Zire 71 Motherboard/Screen Replacement: 步骤 8 中的图像 1,2 Palm Zire 71 Motherboard/Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  9. Palm Zire 71 Motherboard/Screen Replacement: 步骤 9 中的图像 1,3 Palm Zire 71 Motherboard/Screen Replacement: 步骤 9 中的图像 2,3 Palm Zire 71 Motherboard/Screen Replacement: 步骤 9 中的图像 3,3
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  10. Palm Zire 71 Motherboard/Screen Replacement: 步骤 10 中的图像 1,3 Palm Zire 71 Motherboard/Screen Replacement: 步骤 10 中的图像 2,3 Palm Zire 71 Motherboard/Screen Replacement: 步骤 10 中的图像 3,3
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
  11. Palm Zire 71 Motherboard/Screen Replacement, Motherboard/Screen: 步骤 11 中的图像 1,2 Palm Zire 71 Motherboard/Screen Replacement, Motherboard/Screen: 步骤 11 中的图像 2,2
    • Remove Philips screw #00
    • Remove black plastic top part
  12. Palm Zire 71 Motherboard/Screen Replacement: 步骤 12 中的图像 1,3 Palm Zire 71 Motherboard/Screen Replacement: 步骤 12 中的图像 2,3 Palm Zire 71 Motherboard/Screen Replacement: 步骤 12 中的图像 3,3
    • Pull off the orange cable
    • Now the screen and the motherboard can be separated
    • Finished
结论
Jinxian Jiang
于04/28/11注册
245 声望
创作了3篇指南
团队
CSU Los Angeles, Team 1-5, Nelson Spring 2011 CSU Los Angeles, Team 1-5, Nelson Spring 2011 的会员
CSULA-NELSON-S11S1G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 2,833
