跳转到主内容
Palm Zire 71 Back Cover Replacement
你所需要的
  1. Palm Zire 71 Back Cover Replacement, Preparation: 步骤 1 中的图像 1,1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Back Cover Replacement, Top Screws (2) Removal: 步骤 2 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Back Cover Replacement, Bottom Screws (3) Removal: 步骤 3 中的图像 1,1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Back Cover Replacement, Front Panel Removal: 步骤 4 中的图像 1,2 Palm Zire 71 Back Cover Replacement, Front Panel Removal: 步骤 4 中的图像 2,2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: 步骤 5 中的图像 1,2 Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: 步骤 5 中的图像 2,2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Back Cover Replacement, Back Cover: 步骤 6 中的图像 1,2 Palm Zire 71 Back Cover Replacement, Back Cover: 步骤 6 中的图像 2,2
    • Slide the back cover off.
结论
另外一个人完成了本指南。
Jinxian Jiang
于04/28/11注册
245 声望
创作了3篇指南
团队
CSU Los Angeles, Team 1-5, Nelson Spring 2011 CSU Los Angeles, Team 1-5, Nelson Spring 2011 的会员
CSULA-NELSON-S11S1G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 2,461
