跳转到主内容
Palm Zire 31 Screen Replacement
你所需要的
  1. Palm Zire 31 Screen Replacement, Case: 步骤 1 中的图像 1,1
    • Unscrew the two 7.35mm Torx T6 screws.
  2. Palm Zire 31 Screen Replacement: 步骤 2 中的图像 1,1
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  3. Palm Zire 31 Screen Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  4. Palm Zire 31 Screen Replacement: 步骤 4 中的图像 1,1
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
  5. Palm Zire 31 Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Carefully pull back the brown cable holders and separate the screen from the motherboard.
结论
Gabe
于01/23/11注册
501 声望
创作了5篇指南
团队
Cal Poly, Team 5-21, Amido Winter 2011 Cal Poly, Team 5-21, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G21
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 2,487
