跳转到主内容
Palm Zire 21 Battery Replacement
你所需要的
  1. Palm Zire 21 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Palm Zire 21 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two 0.8mm screws located on the back of the device.
  2. Palm Zire 21 Battery Replacement: 步骤 2 中的图像 1,3 Palm Zire 21 Battery Replacement: 步骤 2 中的图像 2,3 Palm Zire 21 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the back cover from the device exposing the battery.
  3. Palm Zire 21 Battery Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, small flathead screwdriver, or small knife blade pry the battery away from the motherboard. Be careful not to pry to fast, or you could rip the wires off during this stage.
  4. Palm Zire 21 Battery Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the battery from the motherboard.
  5. Palm Zire 21 Battery Replacement: 步骤 5 中的图像 1,1
    • Unwrap the old battery from electrical tape and replace with new battery.
结论
Jeremy Craft
于09/26/14注册
301 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 1,359
