简介
In this repair guide it will be described how to replace a broken screen on a Palm Vx orgainizer.
你所需要的
在这个步骤中使用的工具:Tweezers$4.99
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
结论
