跳转到主内容
Palm Treo Pro Speaker Replacement
你所需要的
  1. Palm Treo Pro Speaker Replacement, Battery: 步骤 1 中的图像 1,3 Palm Treo Pro Speaker Replacement, Battery: 步骤 1 中的图像 2,3 Palm Treo Pro Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Press down on the back of the case and slide forward to remove it.
  2. Palm Treo Pro Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling up on the tab near the camera lens.
    • Insert the new battery into the open slot. Make sure the battery is oriented so that the Palm logo is in the upper-left corner opposite the camera lens.
  3. Palm Treo Pro Speaker Replacement, Motherboard: 步骤 3 中的图像 1,3 Palm Treo Pro Speaker Replacement, Motherboard: 步骤 3 中的图像 2,3 Palm Treo Pro Speaker Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
    • Be careful not to misplace these screws as they are very small and will be important during reassembly.
    • If the screws are stripped a flat head screw driver may be necessary.
  4. Palm Treo Pro Speaker Replacement: 步骤 4 中的图像 1,3 Palm Treo Pro Speaker Replacement: 步骤 4 中的图像 2,3 Palm Treo Pro Speaker Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
  5. Palm Treo Pro Speaker Replacement: 步骤 5 中的图像 1,3 Palm Treo Pro Speaker Replacement: 步骤 5 中的图像 2,3 Palm Treo Pro Speaker Replacement: 步骤 5 中的图像 3,3
    • Remove the main plastic body
    • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
    • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
  6. Palm Treo Pro Speaker Replacement: 步骤 6 中的图像 1,3 Palm Treo Pro Speaker Replacement: 步骤 6 中的图像 2,3 Palm Treo Pro Speaker Replacement: 步骤 6 中的图像 3,3
    • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
    • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
  7. Palm Treo Pro Speaker Replacement: 步骤 7 中的图像 1,2 Palm Treo Pro Speaker Replacement: 步骤 7 中的图像 2,2
    • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
  8. Palm Treo Pro Speaker Replacement: 步骤 8 中的图像 1,3 Palm Treo Pro Speaker Replacement: 步骤 8 中的图像 2,3 Palm Treo Pro Speaker Replacement: 步骤 8 中的图像 3,3
    • There are two ribbon cables under the yellow tape.
    • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
    • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
  9. Palm Treo Pro Speaker Replacement: 步骤 9 中的图像 1,3 Palm Treo Pro Speaker Replacement: 步骤 9 中的图像 2,3 Palm Treo Pro Speaker Replacement: 步骤 9 中的图像 3,3
    • Use a plastic opening tool to lift the motherboard up and out of the phone case
    • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
    • It can easily be disconnected with your fingers
    • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
    • The motherboard has now been completely removed
  10. Palm Treo Pro Speaker Replacement, Speaker: 步骤 10 中的图像 1,1
    • Insert your plastic pry in the gap at the top of the phone above the speaker.
  11. Palm Treo Pro Speaker Replacement: 步骤 11 中的图像 1,3 Palm Treo Pro Speaker Replacement: 步骤 11 中的图像 2,3 Palm Treo Pro Speaker Replacement: 步骤 11 中的图像 3,3
    • Gently pry the speaker until it comes out of its holder. This should not take a lot of force to do.
  12. Palm Treo Pro Speaker Replacement: 步骤 12 中的图像 1,1
    • The speaker can be gently lifted off the phone and set aside for cleaning, repair, or replacement.
结论
另外一个人完成了本指南。
AJ Fite
于04/18/13注册
21 声望
创作了2篇指南
团队
Cal Poly, Team 8-59, Johann Spring 2013 Cal Poly, Team 8-59, Johann Spring 2013 的会员
CPSU-JOHANN-S13S8G59
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 156
