简介
How to replace the keyboard on your Palm Treo Pro
你所需要的
Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
Use the plastic opening tool to pry the side of the display glass up so you can easily remove it with your hand.
Locate the four tabs above the keyboard. The following steps will demonstrate how to remove the metal plate from the tabs, which will reveal the keyboard.
另外一个人完成了本指南。
