跳转到主内容
Palm Treo 755p Antenna Replacement
你所需要的
  1. Palm Treo 755p Antenna Replacement, Battery: 步骤 1 中的图像 1,3 Palm Treo 755p Antenna Replacement, Battery: 步骤 1 中的图像 2,3 Palm Treo 755p Antenna Replacement, Battery: 步骤 1 中的图像 3,3
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
  2. Palm Treo 755p Antenna Replacement: 步骤 2 中的图像 1,2 Palm Treo 755p Antenna Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by lifting up on one side.
  3. Palm Treo 755p Antenna Replacement, Back Cover: 步骤 3 中的图像 1,2 Palm Treo 755p Antenna Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
  4. Palm Treo 755p Antenna Replacement: 步骤 4 中的图像 1,1
    • Use a T5 screwdriver to remove the five 7 mm black/red back case screws.
    • Use a T5 screwdriver to remove the middle 3.1 mm screw.
  5. Palm Treo 755p Antenna Replacement: 步骤 5 中的图像 1,2 Palm Treo 755p Antenna Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • The side volume control buttons may fall out after opening the device.
  6. Palm Treo 755p Antenna Replacement: 步骤 6 中的图像 1,2 Palm Treo 755p Antenna Replacement: 步骤 6 中的图像 2,2
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the red box.
    • Potential for device damage: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  7. Palm Treo 755p Antenna Replacement: 步骤 7 中的图像 1,3 Palm Treo 755p Antenna Replacement: 步骤 7 中的图像 2,3 Palm Treo 755p Antenna Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
  8. Palm Treo 755p Antenna Replacement, Antenna: 步骤 8 中的图像 1,1
    • The antenna is on the back half of the phone.
  9. Palm Treo 755p Antenna Replacement: 步骤 9 中的图像 1,2 Palm Treo 755p Antenna Replacement: 步骤 9 中的图像 2,2
    • Press in the four black clips using a spudger to pop off the upper-back cover.
  10. Palm Treo 755p Antenna Replacement: 步骤 10 中的图像 1,1
    • Lift off the top of the back cover from the phone frame.
  11. Palm Treo 755p Antenna Replacement: 步骤 11 中的图像 1,2 Palm Treo 755p Antenna Replacement: 步骤 11 中的图像 2,2
    • Gently pop off the antenna by pulling it away from the back cover.
结论
Mike Shaw
于01/03/11注册
601 声望
创作了6篇指南
团队
Cal Poly, Team 14-6, Forte Winter 2011 Cal Poly, Team 14-6, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G6
6 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,754
