跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. Press the button located just above the Sprint™ logo and then slide the cover down. Press the button located just above the Sprint™ logo and then slide the cover down. Press the button located just above the Sprint™ logo and then slide the cover down.
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Use the small notch on the left hand side of the phone to remove the battery. Use the small notch on the left hand side of the phone to remove the battery.
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Remove the stylus from the phone.
    • Remove the stylus from the phone.
  4. After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
  5. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  6. Using the spudger, remove the small rubberized patch under the antenna.
    • Using the spudger, remove the small rubberized patch under the antenna.
  7. Unscrew the last two screws using the previous screw driver.
    • Unscrew the last two screws using the previous screw driver.
  8. Using the plastic opening tool, gently separate the back case from the phone body. Using the plastic opening tool, gently separate the back case from the phone body.
    • Using the plastic opening tool, gently separate the back case from the phone body.
  9. Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3). Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3). Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
  10. Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1). Once unscrewed, gently detach the antenna chip with your hands (Picture 2). Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
  11. Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1). Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
  12. To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2). Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3). Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
  13. Once the motherboard is removed, the LCD should be resting on the front case of the phone.
    • Once the motherboard is removed, the LCD should be resting on the front case of the phone.
结论
Lucas
于2012年04月17日注册
14 信誉积分
撰写一个指南
团队
Cal Poly, Team 12-37, Regan Spring 2012 Cal Poly, Team 12-37, Regan Spring 2012 的会员
CPSU-REGAN-S12S12G37
4 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 676
