简介
This guide will show you how to easily remove and repair a dysfunctional Palm Treo 680 LCD Screen/Touch Screen with 4 easy steps.
你所需要的
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Remove the 27mm top-left screw using a T6 Torx screwdriver.
Use a T5 Torx screwdriver instead of a T6. T6 is too big.
I found T5 too large as well. T4 seeems to work
Take the front of the pannel and take notice that the screen is attached by a piece of silver tape.
Using a pair of tweezers, carefully peel off this piece of silver tape.
Remove the screen from the front pannel by pushing it out.
Flip the screen over 180 degrees and take off the metal piece that cushions the screen.
Flip the screen over another another 180 degrees and place pressure on the bottom ribbon (Where my left thumb is).
Slightly start to pull apart the touch screen from the LCD screen by placing your thumbs where my thumbs are.
2等其他人完成本指南。
2条评论
where can i get the new touch scree, actually my mobile has fallen down and broken the touch scree. i am a resident in India, Andhra Pradesh, Hyderabad........at Ramkote.... please give me message at chinthala.prasad@yahoo.com please
These are very nice instructions. They are clear and detailed for anyone to follow. Thanks for putting together the steps and sharing it.
I have not tried all steps completely yet. But will do so. I will left with probably a question what to do with touch screen. My phone has
never fallen down nor damaged. It worked perfectly well and one fine day, touch screen stopped working. In any case, I will try.
RJ
Ravi Joshi - 回复
Donde puedo comprar un telefono palm
lupem5635 - 回复
Meurge porfabor
lupem5635 - 回复
