跳转到主内容
Palm Treo 680 Keyboard Replacement
你所需要的
  1. Palm Treo 680 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Palm Treo 680 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 Keyboard Replacement, Back Panel: 步骤 3 中的图像 1,2 Palm Treo 680 Keyboard Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 Keyboard Replacement: 步骤 4 中的图像 1,2 Palm Treo 680 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 Keyboard Replacement: 步骤 6 中的图像 1,3 Palm Treo 680 Keyboard Replacement: 步骤 6 中的图像 2,3 Palm Treo 680 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Palm Treo 680 Keyboard Replacement, Motherboard: 步骤 7 中的图像 1,2 Palm Treo 680 Keyboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Slide the slim metal plate upwards until it disconnects from the motherboard.
    • DO NOT bend or crinkle this metal plate. It will be VERY DIFFICULT, IF NOT IMPOSSIBLE, to slide it back into place when you are re-assembling if you bend or crinkle this metal plate.
  8. Palm Treo 680 Keyboard Replacement: 步骤 8 中的图像 1,2 Palm Treo 680 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Locate the orange ribbon that connects the screen to the motherboard.
    • Use tweezers to peel off the small piece of tape over the orange ribbon connector.
  9. Palm Treo 680 Keyboard Replacement: 步骤 9 中的图像 1,2 Palm Treo 680 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Slide the spudger between the orange ribbon and black connector. Flip the black connector upwards to release the orange ribbon.
    • Using the spudger, pull the orange ribbon away from the connector to confirm the wire is fully disconnected.
  10. Palm Treo 680 Keyboard Replacement: 步骤 10 中的图像 1,3 Palm Treo 680 Keyboard Replacement: 步骤 10 中的图像 2,3 Palm Treo 680 Keyboard Replacement: 步骤 10 中的图像 3,3
    • Carefully turn the phone over so the screen is face up.
    • Locate the other orange ribbon that connects the motherboard to the faceplate.
    • Slide the spudger between the orange ribbon and tan connector. Lift the tan connector up to release the orange ribbon.
    • Separate the motherboard and faceplate of the Palm Treo.
  11. Palm Treo 680 Keyboard Replacement, Keyboard: 步骤 11 中的图像 1,2 Palm Treo 680 Keyboard Replacement, Keyboard: 步骤 11 中的图像 2,2
    • Locate the backside of the Treo's faceplate.
    • Remove the two screws using the T6 Torx screwdriver.
  12. Palm Treo 680 Keyboard Replacement: 步骤 12 中的图像 1,2 Palm Treo 680 Keyboard Replacement: 步骤 12 中的图像 2,2
    • Take off the plastic back panel, to gain access to the rubber keys of the keyboard.
    • Push on the keys and function bar from the front of the Treo. They should all pop right out.
结论
另外一个人完成了本指南。
Maiya123
于10/22/09注册
51 声望
创作了6篇指南
团队
Cal Poly, Team 6-4, Maness Fall 2009 Cal Poly, Team 6-4, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 4,814
