跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Palm Treo 680 Back Panel Replacement
你所需要的
  1. Palm Treo 680 Back Panel Replacement, Battery: 步骤 1 中的图像 1,2 Palm Treo 680 Back Panel Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 Back Panel Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 Back Panel Replacement, Back Panel: 步骤 3 中的图像 1,2 Palm Treo 680 Back Panel Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Remove the stylus in order to access the screw.
    • Unscrew the 0.266 inch top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 Back Panel Replacement: 步骤 4 中的图像 1,2 Palm Treo 680 Back Panel Replacement: 步骤 4 中的图像 2,2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Unscrew the 0.266 inch screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 Back Panel Replacement: 步骤 5 中的图像 1,1
    • Remove the remaining two 0.266 inch screws at the bottom using the T6 screwdriver.
  6. Palm Treo 680 Back Panel Replacement: 步骤 6 中的图像 1,3 Palm Treo 680 Back Panel Replacement: 步骤 6 中的图像 2,3 Palm Treo 680 Back Panel Replacement: 步骤 6 中的图像 3,3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
结论
Maiya123
于10/22/09注册
51 声望
创作了6篇指南
团队
Cal Poly, Team 6-4, Maness Fall 2009 Cal Poly, Team 6-4, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,966
