跳转到主内容
Palm Treo 650 Speaker Replacement
你所需要的
  1. Palm Treo 650 Speaker Replacement, Battery and Stylus: 步骤 1 中的图像 1,1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Speaker Replacement: 步骤 2 中的图像 1,1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Speaker Replacement: 步骤 3 中的图像 1,2 Palm Treo 650 Speaker Replacement: 步骤 3 中的图像 2,2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Speaker Replacement, Case: 步骤 4 中的图像 1,1
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Speaker Replacement: 步骤 5 中的图像 1,2 Palm Treo 650 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Speaker Replacement: 步骤 6 中的图像 1,1
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Speaker Replacement: 步骤 7 中的图像 1,2 Palm Treo 650 Speaker Replacement: 步骤 7 中的图像 2,2
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Speaker Replacement, Speaker: 步骤 8 中的图像 1,2 Palm Treo 650 Speaker Replacement, Speaker: 步骤 8 中的图像 2,2
    • Using an ipod case opener or similar tool, simply pry off the speaker.
    • This may be glued in, so remove carefully.
结论
cgood
于10/28/09注册
122 声望
创作了7篇指南
团队
Cal Poly, Team 19-3, Maness Fall 2009 Cal Poly, Team 19-3, Maness Fall 2009 的会员
CPSU-MANESS-F09S19G3
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,424
