当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using a plastic opening tool, carefully separate the front and back cases.
Note: The antenna will detach from the phone.
Using a T6 Torx Screwdriver, remove the two screws.
The motherboard will now be loose from the front case.
The screen is connected to the phone with an orange data cable.
Slide the spudger as close to the connection as possible.
Gently pull the spudger up and the cable should come out of the socket.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
