跳转到主内容
Palm Treo 600 Screen Replacement
你所需要的
  1. Palm Treo 600 Screen Replacement, Back Case: 步骤 1 中的图像 1,1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Screen Replacement: 步骤 2 中的图像 1,2 Palm Treo 600 Screen Replacement: 步骤 2 中的图像 2,2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Screen Replacement: 步骤 3 中的图像 1,2 Palm Treo 600 Screen Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Screen Replacement, Front Case: 步骤 4 中的图像 1,2 Palm Treo 600 Screen Replacement, Front Case: 步骤 4 中的图像 2,2
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
  5. Palm Treo 600 Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • The screen is connected to the phone with an orange data cable.
    • Slide the spudger as close to the connection as possible.
    • Gently pull the spudger up and the cable should come out of the socket.
  6. Palm Treo 600 Screen Replacement: 步骤 6 中的图像 1,2 Palm Treo 600 Screen Replacement: 步骤 6 中的图像 2,2
    • Once the cable is unplugged, you can remove the screen from the body.
结论
团队
Cal Poly, Team 13-23, Maness Winter 2010 Cal Poly, Team 13-23, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G23
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,179
