跳转到主内容
修复你的物品
维修的权力
商店
简介
After you have taken off the back case, the front case can also be removed to help you complete other teardown guides.
配件
没有特定配件。
  1. On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Use the T6 Torx Screwdriver to remove all 4 screws. You have to first remove the Stylus to  access the 4th screw.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
    Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
  4. Using a plastic opening tool, carefully separate the front and back cases. Note: The antenna will detach from the phone.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  5. Using a T6 Torx Screwdriver, remove the two screws. The motherboard will now be loose from the front case.
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
结论
Michael Polka
于2010年01月27日注册
22 信誉积分
撰写一个指南
团队
Cal Poly, Team 13-23, Maness Winter 2010 Cal Poly, Team 13-23, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G23
4 名成员
创作了16篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 2,503
