当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Use the T6 Torx Screwdriver to remove all 4 screws.
You have to first remove the Stylus to access the 4th screw.
Using a plastic opening tool, carefully separate the front and back cases.
Note: The antenna will detach from the phone.
Using metal tweezers, unplug small white plug.
Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
The battery may be glued to the phone.
取消:我没有完成这个指南。
2等其他人完成本指南。
与7其他贡献者
于01/26/10注册
24 声望
创作了7篇指南
徽章: 8
+ 5更多徽章
CPSU-MANESS-W10S13G23
4 名成员
创作了16篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 5,536
