跳转到主内容
加入维修社区 - 创建账户
Palm Rest Disassembly
你所需要的
  1. Palm Rest Disassembly, Battery: 步骤 1 中的图像 1,1
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. Palm Rest Disassembly: 步骤 2 中的图像 1,2 Palm Rest Disassembly: 步骤 2 中的图像 2,2
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. Palm Rest Disassembly: 步骤 3 中的图像 1,2 Palm Rest Disassembly: 步骤 3 中的图像 2,2
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. Palm Rest Disassembly: 步骤 4 中的图像 1,2 Palm Rest Disassembly: 步骤 4 中的图像 2,2
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. Palm Rest Disassembly: 步骤 5 中的图像 1,3 Palm Rest Disassembly: 步骤 5 中的图像 2,3 Palm Rest Disassembly: 步骤 5 中的图像 3,3
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
  6. Palm Rest Disassembly, Palm Rest Disassembly: 步骤 6 中的图像 1,1
    • Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
  7. Palm Rest Disassembly: 步骤 7 中的图像 1,1
    • Pry up and detach the keyboard. Starting at the top, slowly work the side and pull the keyboard away from you to unseat the bottom tabs.
  8. Palm Rest Disassembly: 步骤 8 中的图像 1,1
    • Remove the keyboard connection from the laptop by flipping up the black tab on the ZIF connector.
  9. Palm Rest Disassembly: 步骤 9 中的图像 1,2 Palm Rest Disassembly: 步骤 9 中的图像 2,2
    • Remove the palm rest using the blue spudger tool.
  10. Palm Rest Disassembly: 步骤 10 中的图像 1,1
    • Remove the five 3 mm PH1 Phillips head screws underneath keyboard.
  11. Palm Rest Disassembly: 步骤 11 中的图像 1,1
    • Remove metal keyboard underlayment.
    • There is no way to separate the palm rest from the keyboard. They both are removed as an assembly.
结论
团队
UMass Dartmouth, Team S1-G4, Simcock Fall 2017 UMass Dartmouth, Team S1-G4, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G4
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 85
总计 1,733
