跳转到主内容
Palm Pre Volume Button Replacement
你所需要的
  1. Palm Pre Volume Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Palm Pre Volume Button Replacement: 步骤 2 中的图像 1,1
    • Carefully pull up on the tab to remove the current battery.
    • Locate the volume cavity on the right of the back frame.
    • Take your new volume button and slide in into the slot until the opposite end clicks.
    • You will have to use some force to do so.
结论
noha
于04/12/12注册
139 声望
创作了6篇指南
团队
Cal Poly, Team 7-31, Maness Spring 2012 Cal Poly, Team 7-31, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G31
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 302
