跳转到主内容
Palm Pre Speaker Replacement
你所需要的
  1. Palm Pre Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Palm Pre Speaker Replacement: 步骤 2 中的图像 1,1
    • Carefully pull up on the tab to remove the current battery.
  3. Palm Pre Speaker Replacement, Speaker: 步骤 3 中的图像 1,2 Palm Pre Speaker Replacement, Speaker: 步骤 3 中的图像 2,2
    • Use the t4 screwdriver to remove all 6 of the 3.6mm long screws.
  4. Palm Pre Speaker Replacement: 步骤 4 中的图像 1,2 Palm Pre Speaker Replacement: 步骤 4 中的图像 2,2
    • Use the spudger to locate the crease at the bottom of the keyboard.
    • Carefully work your way around the phone separating the back frame from the keyboard.
  5. Palm Pre Speaker Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the DIV and GPS antennas from the back of the keyboard.
  6. Palm Pre Speaker Replacement: 步骤 6 中的图像 1,1
    • Use the spuger to pry out the speaker. It is magnetically connected so do not be afraid to use the necessary force.
    • Make sure to take note of the orientation of the speaker for re-installation.
    • Make sure not the puncture the screen on the outside of the back frame.
结论
noha
于04/12/12注册
139 声望
创作了6篇指南
团队
Cal Poly, Team 7-31, Maness Spring 2012 Cal Poly, Team 7-31, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G31
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,175
