跳转到主内容
Palm Pre Speaker Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Palm Pre Speaker Replacement, Antenna: 步骤 1 中的图像 1,2 Palm Pre Speaker Replacement, Antenna: 步骤 1 中的图像 2,2
    • First the back panel must be removed to reveal the battery.
    • Remove the battery pack.
  2. Palm Pre Speaker Replacement: 步骤 2 中的图像 1,2 Palm Pre Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the six T5 screws necessary to separate the backplate from the phone.
    • There is one screw in the upper right that is concealed by a small sticker labeled "Palm."
    • Additionally, there are interlocking tabs securing the back plate around the edges.
    • Use the opening tool to carefully go around the phone releasing these tabs.
  3. Palm Pre Speaker Replacement: 步骤 3 中的图像 1,2 Palm Pre Speaker Replacement: 步骤 3 中的图像 2,2
    • Lift the metal flap marked in red to reveal the antenna connectors.
    • Carefully pry these the antennas from their connections, this can be done quite easily.
    • Take note of which colored wire is attached to each connection. The white wire corresponds to GPS, while the black wire corresponds to DIV, or diversity antenna.
  4. Palm Pre Speaker Replacement, Speaker: 步骤 4 中的图像 1,3 Palm Pre Speaker Replacement, Speaker: 步骤 4 中的图像 2,3 Palm Pre Speaker Replacement, Speaker: 步骤 4 中的图像 3,3
    • With the backplate removed, the speaker is visible.
    • Pry out speaker with spudger.
    • It is magnetically attached so there should be a little bit of resistance; however, there are no wires to disconnect.
    • Take note of the orientation of the speaker for re-installation.
结论
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 312
