跳转到主内容
Palm Pre Keypad Control Board Replacement
你所需要的
  1. Palm Pre Keypad Control Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Palm Pre Keypad Control Board Replacement: 步骤 2 中的图像 1,1
    • Carefully pull up on the tab to remove the current battery.
  3. Palm Pre Keypad Control Board Replacement, Antenna: 步骤 3 中的图像 1,2 Palm Pre Keypad Control Board Replacement, Antenna: 步骤 3 中的图像 2,2
    • Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
  4. Palm Pre Keypad Control Board Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Locate the hinge that covers the black and white GPS and DIV antennas. (The hinge will be located in the red box as portrayed in the picture.)
    • Use a spudger to pry open the hinge.
    • Use tweezers to disconnect the antennas from the keypad control board.
  5. Palm Pre Keypad Control Board Replacement: 步骤 5 中的图像 1,2 Palm Pre Keypad Control Board Replacement: 步骤 5 中的图像 2,2
    • Use a spudger to pry off the (black and yellow) back frame.
    • Disregard the main part of the phone at this point and look only at the inside of the removed back frame. (You will need the main part of the phone for access to the keyboard and motherboard)
  6. Palm Pre Keypad Control Board Replacement: 步骤 6 中的图像 1,1
    • Find the small circuit board at the top right and desolder the wires that are connected to it.
    • This step is only necessary for antenna removal.
  7. Palm Pre Keypad Control Board Replacement, Keypad Control Board: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the two ribbon cable connectors using tweezers.
  8. Palm Pre Keypad Control Board Replacement: 步骤 8 中的图像 1,2 Palm Pre Keypad Control Board Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to remove the keypad control board.
    • There is heavy adhesive connecting this part to the keypad sensors.
结论
noha
于04/12/12注册
139 声望
创作了6篇指南
团队
Cal Poly, Team 7-31, Maness Spring 2012 Cal Poly, Team 7-31, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G31
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 797
