跳转到主内容
Palm Pre Antenna Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Palm Pre Antenna Replacement, Antenna: 步骤 1 中的图像 1,2 Palm Pre Antenna Replacement, Antenna: 步骤 1 中的图像 2,2
    • First the back panel must be removed to reveal the battery.
    • Remove the battery pack.
  2. Palm Pre Antenna Replacement: 步骤 2 中的图像 1,2 Palm Pre Antenna Replacement: 步骤 2 中的图像 2,2
    • Remove the six T5 screws necessary to separate the backplate from the phone.
    • There is one screw in the upper right that is concealed by a small sticker labeled "Palm."
    • Additionally, there are interlocking tabs securing the back plate around the edges.
    • Use the opening tool to carefully go around the phone releasing these tabs.
  3. Palm Pre Antenna Replacement: 步骤 3 中的图像 1,2 Palm Pre Antenna Replacement: 步骤 3 中的图像 2,2
    • Lift the metal flap marked in red to reveal the antenna connectors.
    • Carefully pry these the antennas from their connections, this can be done quite easily.
    • Take note of which colored wire is attached to each connection. The white wire corresponds to GPS, while the black wire corresponds to DIV, or diversity antenna.
结论
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 351
