跳转到主内容
Palm Pilot Professional 3com LCD Screen Replacement
你所需要的
  1. Palm Pilot Professional 3com LCD Screen Replacement, Keypad: 步骤 1 中的图像 1,1
    • Unscrew the three screws on the back of the Palm Pilot.
  2. Palm Pilot Professional 3com LCD Screen Replacement: 步骤 2 中的图像 1,2 Palm Pilot Professional 3com LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Pull the back cover from the bottom of the device and separate the interlocking tabs on the top to remove the back cover.
  3. Palm Pilot Professional 3com LCD Screen Replacement: 步骤 3 中的图像 1,1
    • The front plastic cover is now free to be removed from the rest of the device.
  4. Palm Pilot Professional 3com LCD Screen Replacement: 步骤 4 中的图像 1,1
    • The keypad is now free to be removed from the rest of the device.
  5. Palm Pilot Professional 3com LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 1,1
    • Looking at the back of the device hold one of the white tabs on the ribbon cable connector down and use tweezers to push in the other white tab toward the device at the same time.
  6. Palm Pilot Professional 3com LCD Screen Replacement: 步骤 6 中的图像 1,1
    • The ribbon cable is now loose. Use the tweezers to carefully slide the ribbon cable out of the connector.
  7. Palm Pilot Professional 3com LCD Screen Replacement: 步骤 7 中的图像 1,2 Palm Pilot Professional 3com LCD Screen Replacement: 步骤 7 中的图像 2,2
    • The screen is now disconnected from the rest of the device and can now be removed.
结论
Kevin Santos
于03/09/12注册
1 声望
创作了4篇指南
团队
Clemson, Team 2-4, Benson Spring 2012 Clemson, Team 2-4, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,494
