本指南有最近更改,您可查看未经巡查的最新版本。
简介
The circuit board contains the CPU, hot sync port, and infrared port. If any of these things aren't working, the circuit board may be the cause.
你所需要的
Using a Philips #0 or #00 screwdriver, locate and unscrew the four screws holding the back cover on the device.
Locate the brown serial connector on the left side of the device. Using the flat head screw driver, push the little tabs (one on each side) out towards you as pictured.
They should extend about 1/16 of an inch (1.5 mm).
Now take the screwdriver/tweezers and gently pry out the serial tab as shown .
