跳转到主内容
Palm IIIc Screen Replacement
你所需要的
  1. Palm IIIc Screen Replacement, Removing broken LCD screen: 步骤 1 中的图像 1,1
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Palm IIIc Screen Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Palm IIIc Screen Replacement, Remove the Front and Back Covers: 步骤 3 中的图像 1,1
    • Using a spudger, carefully pry open the front and back covers along the side seam.
    • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
  4. Palm IIIc Screen Replacement, Screen: 步骤 4 中的图像 1,1
    • Unhook the battery cable from the motherboard and remove the battery.
  5. Palm IIIc Screen Replacement: 步骤 5 中的图像 1,2 Palm IIIc Screen Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • On the back of the motherboard use tweezers to pull up the ZIF connector which looks like a brown plastic tab.
    • Once the ZIF connector is unattached, remove the clear screen cover.
  6. Palm IIIc Screen Replacement: 步骤 6 中的图像 1,1
    • Using tweezers unhook the blue and red screen cables where they connect to the motherboard.
  7. Palm IIIc Screen Replacement: 步骤 7 中的图像 1,3 Palm IIIc Screen Replacement: 步骤 7 中的图像 2,3 Palm IIIc Screen Replacement: 步骤 7 中的图像 3,3
    • Using tweezers, pull up the other two ZIF connector tabs.
  8. Palm IIIc Screen Replacement: 步骤 8 中的图像 1,1
    • Gently pull the black clips on the inside case to detach the motherboard from the device. Pull the motherboard out towards the bottom left corner.
  9. Palm IIIc Screen Replacement: 步骤 9 中的图像 1,1
    • Pull the screen out from the front.
结论
Paulina Trujillo
于04/07/11注册
265 声望
创作了8篇指南
团队
Cal Poly, Team 20-69, Walters Spring 2011 Cal Poly, Team 20-69, Walters Spring 2011 的会员
CPSU-WALTERS-S11S20G69
5 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 1,137
