跳转到主内容
Palm IIIc Battery Replacement
你所需要的
  1. Palm IIIc Battery Replacement, Removing broken LCD screen: 步骤 1 中的图像 1,1
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Palm IIIc Battery Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Palm IIIc Battery Replacement, Remove the Front Cover: 步骤 3 中的图像 1,1
    • Lay Palm IIIc face-up and remove the front cover.
    • Do this firmly but not with too much force so as to not break or disturb anything you're not supposed to.
  4. Palm IIIc Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Carefully pop out the battery, without disturbing the surroundings.
    • Prying tool will facilitate this step.
  5. Palm IIIc Battery Replacement: 步骤 5 中的图像 1,1
    • Detach the wire connecting the battery to the motherboard.
  6. Palm IIIc Battery Replacement: 步骤 6 中的图像 1,1
    • Attach the new battery by connecting it to the motherboard via the red wire.
结论
另外一个人完成了本指南。
Paulina Trujillo
于04/07/11注册
265 声望
创作了8篇指南
团队
Cal Poly, Team 20-69, Walters Spring 2011 Cal Poly, Team 20-69, Walters Spring 2011 的会员
CPSU-WALTERS-S11S20G69
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 4,192
