当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Caution: Turn cell phone off before removing battery!
Press battery to the right.
Then lift up battery pack to remove.
Lift the rubber cap at the top right to reveal the sixth screw.
Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
Remove the six screws using the T5 Torx screwdriver.
Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
Be very careful, these electronics are delicate!
Pry the four plastic latches free that connect the antenna to the logic board.
Excessive force may damage your logic board!
Remove the antenna from the logic board.
The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
The speaker should be placed back into its spot in the correct position. Take notice of the gold connectors
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
